1992 Lincoln Continental White Smoke
FORD
SHORT_BUS_53
Lincoln continental runs smooth but does not idle white smoke comes out of exhaust and a lot of water it is a 92 with a 3.8 v-6 is it the heads or just the gas?
Apr 19, 2006 at 6:58 AM
LOSONE
  • 1,616 POSTS
White smoke is a coolant leak in the combustion chamber. It could be a blown head gasket, intake manifold gasket or cracked heads. STOP the car and don't drive it. bearings don't like water in the oil.
Apr 19, 2006 at 11:17 AM
GAMBLERR
  • 23 POSTS
I have the same year car as you do. I had to do a head job about 2 years ago, at 160,000 miles. I had the same problem, but not as bad as you do. I just notice that my water was going down in my radiator, but I had no leaks, and no water on the ground from the overflow. I would have to keep topping it off about once a week, about a quart or two. I did a compression test, and found one of the cyl was lower then the rest. I pulled the heads and found a bad head gasket. My car had blow a radiator hose about two weeks before, and had overheated. I found that this is a common problem with this engine. I had to remove my heads and take them to a machine shop as the overheating had warped them. I did all the work myself, so the only cost was in materials and the machine shop work. That cost me $75.00 to true up both heads. One thing, if you do the job yourself, make sure you use new head bolts, do not reuse the old ones, not a good idea. There is not a fast cheap fix for this. Good luck.
Apr 20, 2006 at 3:21 AM
LOSONE
  • 1,616 POSTS
GAMBLERR is right in all respects. I am glad he mentioned the head bolts. Good luck!
Apr 20, 2006 at 4:57 AM
SHORT_BUS_53
one other guestion could be the block may have cracked?
Apr 21, 2006 at 2:55 AM
LOSONE
  • 1,616 POSTS
Lets put it this way. The only time I saw a cracked block is when a connecting rod went through the engine when it ran out of oil due to a leak.
Apr 21, 2006 at 4:21 AM
Suggested Repair
Stop driving the car. White smoke and water from the exhaust indicate coolant entering a combustion chamber, most often from a blown head gasket, intake manifold gasket, or warped or cracked heads. Do a compression test, check coolant loss and whether coolant is mixing with the oil, and have the heads checked and resurfaced if they were overheated. Use new head bolts if the heads are removed. A cracked block is unlikely unless the engine suffered severe internal damage.
Conversation Summary
The owner of a 1992 Lincoln Continental with a 3.8 V6 said it runs smoothly but will not idle, with white smoke and a lot of water from the exhaust, and asked whether the heads or the fuel was at fault. An expert said white smoke means coolant is entering a combustion chamber from a blown head gasket, intake manifold gasket, or cracked heads, and advised stopping the car because water in the oil can damage the bearings. Another owner reported the same engine lost coolant without external leaks, had a low cylinder on a compression test, and needed a head-gasket repair plus machine-shop work after overheating warped the heads; new head bolts were recommended. The expert agreed and said a cracked block is uncommon and usually follows severe oil-loss damage rather than this symptom.
