1991 Lincoln Continental Rough Running
MAVIS
I have a 1991 Lincoln Continental Executive Series with approx 250,00 mileage. Engine size is a V8.
When driving the vehicle, it is very rough.
It's seems not to be getting enough gas while driving(sometimes only) rather it be driving fast our slow of the freeway. It doesn't matter.
It's like the car hiccups when driving.
Any ideas what could be causing this (i.e. fule pump? fuel line?)
Thanks
May 2, 2007 at 5:41 AM
BESTBET777
  • 89 POSTS
Lot of possibilities, hook up a computer scanner.
May 4, 2007 at 1:12 PM
MSP5SPEED
I would take a look at the EGR Valve (Exhaust Gas Recirculation) my boyfriends 1997 Lincoln Signature Series had the same symptoms as what you've described and I preformed an EGR test and replaced the component and the car runs beautifully now.
Worth a shot.
Good luck
May 31, 2007 at 8:58 AM
Suggested Repair
Scan the computer for diagnostic codes, then inspect and test the EGR valve. A similar Lincoln with the same hiccup and rough-running symptoms improved after the EGR valve was tested and replaced.
Conversation Summary
The owner of a 1991 Lincoln Continental with about 250,000 miles reports rough running and occasional hiccups at various speeds, as if it is not getting enough fuel. One reply says there are many possible causes and recommends connecting a computer scanner. Another suggests testing the EGR valve, noting that replacing it resolved the same symptoms on a similar Lincoln.
