2001 Lincoln Continental Engine runs Great in Park/Neutral
2001 LINCOLN CONTINENTAL
145,000 MILES • V8 • FWD • AUTOMATIC
MUSKYHUNTR
  • 5 POSTS
My mechanic cannot figure out exactly what is wrong with my Lincoln.. I was driving it and all of a sudden it strted running rough. woud strt but run rough all the time, park, neutral, driive. He found a broken valve spring replaced it and got the engine to start up and run great while parked.. On the test drive it runs very rough and stalls out.. place it in park it starts up runs fantastic put it in drive and it runs rough and wants to stall out.. Now 3 mechanics have looked at it and can't figure out whats wrong. No error codes on the multiple scans that they have done with different scan testers. Now the mechanic tells me two cyclinders seem to be dead but there is good compression, spark and fuel to these.
Now he says its all he can do. he doesn't know what's wrong???? I have been going to this mechanic for 30 years and there has NEVER been anything he can't figure out and fix... WELL UP UNTIL NOW
Can you help me & him???
Sep 21, 2010 at 2:05 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Thank You for the Donation.....
Did they test the Injectors and Injector Harnesses?
When they pulled the plugs, did they note the condition?
Have they checked for Vacuum Leaks?
On the possible dead cylinders did they swap coils to varify the possibility of a failed or failing coil.
Sep 21, 2010 at 3:31 AM
MUSKYHUNTR
  • 5 POSTS
They put new injectors in... Don'tknow about the harnesses..They put new plugs in.. I can't be positive on the vacuum leaks but I am sure that they did because he usually does and has found those to be problems in the past.
On the two cyclinders he put new coils in on those cyclinders...
Sep 21, 2010 at 3:36 AM
MUSKYHUNTR
  • 5 POSTS
SO FAR STILL LOOKING FOR A SOLUTION???
Sep 23, 2010 at 12:50 AM
MERLIN2021
  • 17,250 POSTS
Check the harness that runs at the back of the motor against the firewall, Lincoln had problems with that harness.
Sep 24, 2010 at 9:00 AM
MUSKYHUNTR
  • 5 POSTS
The problem was in the harness there were several wires that had lost insulation somehow and were shorting out..
Wires were seperated heast shrinked and problem is now fixed.
Thanks for the help
Oct 6, 2010 at 5:44 AM
MERLIN2021
  • 17,250 POSTS
Your welcome, that was easy eh?
Oct 6, 2010 at 4:17 PM
