1993 Lexus ES 300 93 Es300 Won't start
98,000 MILES • 6 CYL • FWD • AUTOMATIC
NEOHADES
I'm in desperate need of some help. I recently decided to replace my rear valve cover gasket due to some oil dripping and burning off of the exhaust. I was extremely careful not to mess anything up like a ground or connector left unhooked.
So I get everything put back together and when I went to start the car, it would just crank and crank but not turn over. When I went to pull trouble codes, I noticed that my check engine light is out completely even when just turning the key to the on position. I checked every single fuse in the car and none are blown. Is there anything you guys can think of? Help is greatly appreciated.
Thanks
Oct 30, 2008 at 11:35 PM
JAMES W.
  • 2,394 POSTS
Do you have spark at the plugs? Fuel pressure at the fuel rail? Possibilities::: ignition switch or the computer itself. Can you find (for sure) the fuse for the ECM, and is it good?
Oct 31, 2008 at 3:11 PM
