1993 Lexus ES 300
MSTEE1234
  • 1993 LEXUS ES 300
  • 6 CYL
  • 4WD
  • 185,000 MILES
CAR TURNS OVER BUT WON"T START OR FIRE
Friday, July 2nd, 2010 AT 2:44 PM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Friday, July 2nd, 2010 AT 3:28 PM
