1993 Lexus ES 300 2 things
147,000 MILES • 6 CYL • FWD • AUTOMATIC
BLACCONE
I have a 93 es300 and i replaced the head gasket but now the car wont start it turns but wont start and the #4 cylinder floods coud this be caused by the cam sensor? and hoe should the timing marks be set on the camshafts because there are two sets of marks a diagram would be helpful or a very accurate description
Jul 24, 2009 at 3:14 PM
  • 110,248 POSTS
If the cam sensor was bad, I would think all cylenders would flood due to no spark. Recheck the timing marks. I looked it up for you so you can double check your work. But to me, it sounds like there may be a timing problem.
Here is the diagram:
https://www.2carpros.com/car_repair_information/year/1993/make/lexus/model/es_300/1993_lexus_es_300_timing_belt_diagram_marks.htm
Let me know what you find and we'll go from there.
Jul 24, 2009 at 3:54 PM
BLACCONE
Thanks joe for your response and i double checked my marks and such but where can i find the diagrams for the camshaft timing marks that are located under the valve cover?
Jul 25, 2009 at 1:51 AM
  • 110,248 POSTS
I believe the reference marks are for the cam. Do you have something different?
Jul 25, 2009 at 2:41 PM
