Crankshaft position sensor where is it located?
RIANANDERSON
  • 2004 KIA SEDONA
  • 3.5L
  • 6 CYL
  • 175,000 MILES
I need to knw approximately how long does it take for a mechanic shop to install a crankshaft position sensor?
Thursday, January 24th, 2019 AT 2:33 PM (Merged)
  • 31,937 POSTS
The crank shaft position sensor is located behind the front engine cover so there is a bit of work to get to it, Mitchell 1 data base allows 3 hrs, to do the job but I feel that around 2 may be closer to the mark, so to stay safe anywhere between 2-3 should be ample time.
PMOORE88
  • 2002 KIA SEDONA
  • 101,000 MILES
I recently replaced the crankshaft position sensor in my '02 Kia Sedona. No it will no idle correctly. What should I check next.
Check and test the idle air control valve/motor
FREDDY PALACIOS
  • 2003 KIA SEDONA
  • 3.5L
  • V6
  • 178,223 MILES
Twice the van quit running on me got OBD code and now a friend who I borrowed van from says it happened cause the van ran out of gas. Would it cause the crank shaft sensor 2 break?
CARADIODOC
  • 33,912 POSTS
Of course not. You did not list the fault code number or what is wrong with the crankshaft position sensor, but those often fail by becoming heat-sensitive, then they work again after they cool down for about an hour. They are a real common cause of intermittent stalling.
Running out of gas is a common occurrence. That can cause a fuel pump to overheat and fail, but it does not affect other parts.
