2003 Kia Sedona starter
2003 KIA SEDONA
94,222 MILES • 6 CYL • FWD • AUTOMATIC
JASONCOLLINS
my kia sedona 2003 will not start i put it on a charger it said it had a full charge tried to jump it did the smae thing
Feb 21, 2010 at 4:33 AM
Pick your symptom:
**Get back with some results.
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Feb 21, 2010 at 6:19 PM
