2001 Kia Spectra Belt Squeal
2001 KIA
TODDY
My Kia Spectra makes a loud "described as, squealing chalk mark noise" when running with the fan on and sometimes when the accelerator is applied w/out the fan on. Is this a bearing going out?
What do you think and where should I start?
Feb 4, 2007 at 1:08 PM
INDYUKE
  • 416 POSTS
Sounds like a belt squeal. I believe your car has a serpintine belt... one belt that drives all accessories such as A/C, power steering, alternator, etc. It might be going bad. I hope this helps.
Feb 5, 2007 at 3:50 PM
Suggested Repair
Inspect the serpentine belt that drives the accessories and replace it if it is worn, glazed, or slipping.
Conversation Summary
The owner of a 2001 Kia Spectra with 138,000 miles reports a loud chalk-like squeal with the fan on and sometimes when accelerating without the fan, and asks whether a bearing is failing. The expert says it sounds like a belt squeal from a worn serpentine belt that drives the A/C, power steering, alternator, and other accessories.
