2001 Kia Sephia Timing Marks
DNAMASON
I have a 2001 Kia Sephia. I replaced the timmimg belt. I need a diagram on how to time it. can anyone help!!!!
Apr 10, 2006 at 8:28 AM
SDALTON19
  • 87 POSTS
i would post a picture for you to look at unfortunatley this website wont let me best i can tell you on the camshafts there is an I and an E the groove directley above the i and e should line up with the arrows on the platic cover behind the camshaft gears now those are the timing marks for the camshafts the crankshaft has a dot on it that looks like it should point straight up at an arrow on the block itself i hope this helps
May 25, 2006 at 4:09 PM
Suggested Repair
Align the camshaft timing marks so the grooves directly above the I and E marks line up with the arrows on the plastic cover behind the cam gears. Align the crankshaft dot so it points straight up at the arrow on the block.
Conversation Summary
The owner of a 2001 Kia Sephia replaced the timing belt and asked for a timing diagram. An expert described the marks: the grooves above the camshaft I and E marks should line up with arrows on the plastic cover, and the crankshaft dot should point straight up at an arrow on the block.
