2002 Kia Spectra Radio Asks for Code
KIA
IZZYOLI
kia spectra 2002 30000 miles
disconnected battery to replace head light now the radio will only work for approximately 3 mins and it asks for a code does anyone know what that code may be
Apr 25, 2006 at 7:08 AM
SDALTON19
  • 87 POSTS
yes this is an antitheft code if the radio is stolen it keeps the thief from being able to use it unless he has the code very simple procedure for this you should have written the code down when you bought the car in your owners manual also there you will find the procedure for entering the code into the radio if you didnt write the code down call the dealer and have you vin # ready they will ask for that and your name then they will give you the code and tell you how to enter it problem solved
May 25, 2006 at 3:45 PM
Suggested Repair
The radio is asking for its antitheft code after the battery was disconnected. Look up the code and entry procedure in the owner's manual. If the code was not recorded, call a Kia dealer with the VIN and owner name so they can provide the code and entry steps.
Conversation Summary
A 2002 Kia Spectra radio works for about three minutes and then requests a code after the battery was disconnected to replace a headlight. The expert explained that this is the radio antitheft code and advised checking the owner's manual or contacting the dealer with the VIN to obtain the code and entry procedure.
