2002 Kia Spectra Idle Knock Like Diesel
KIA
LFITE
2002 Kia Speactra This only happens when I have not driven my car for a couple hours, in morning and after work.
When my car is in a idle it has the same knocking sounds as a diesel. but when I drive (give it gas) the sound goes away. Any help what might be the problem would be great. Kia WILL NOT look at anything other than what is specified when you bring it in. I already took it to them and they said did not find anything. I already had to replace one transmission after only 2000 miles. Car have almost 60,000 on it now.
Mar 8, 2006 at 2:14 AM
CODY-ODY
  • 57 POSTS
try checking and cleaning the ground for the computer . Its just near the kick panel on the driver's side should have 2 or 3 black wires and a bolt securing it to the body.(just undo it sand both sides of the wires and both surfacesof the body and bolt and retighten it. Its worth a shot and is easy and something anyone can do
Jun 18, 2006 at 1:52 AM
Suggested Repair
Check and clean the computer ground near the driver's side kick panel. Remove the bolt, sand both sides of the ground wires and the body and bolt contact surfaces, then retighten.
Conversation Summary
The owner of a 2002 Kia Spectra reports diesel-like knocking at idle after the car sits for a couple of hours, such as in the morning or after work. The noise goes away when the car is driven. The dealer found nothing. An expert suggests cleaning the computer ground near the driver's side kick panel by sanding the wire, body, and bolt surfaces and retightening the bolt.
