2006 Kia Rio Clicking on Turns
KIA
HEBELL
I have a 2006 Kia Rio Hatchback. Under warranty. Took in and mechanic couldn't hear the noise. It sounds very obvious to me. When turning, especially hard, there is a definate "click click click" coming from the driver side tire area, the vibration of which you can feel in the steering wheel on a tight turn. Is this a normal noise? When my Neon did this once it was the tire-rod, but the mechanic says it all checked out. It didn't make this noise when I first bought it. Any ideas?
May 9, 2006 at 4:53 AM
SDALTON19
  • 87 POSTS
sounds like it maybe a defective cv joint though with the mileage and age you described you may hear it alot better becouse you know its new and still under warranty so your very picky about it it may seem abvious to you but the mechanic may only be looking for more serious problems take it back again and again they will find out whats wrong if only so they dont have to look at your car anymore i hope this helps
May 25, 2006 at 3:35 PM
Suggested Repair
Have the driver-side CV joint inspected and replaced if defective. Return the car under warranty until the clicking on tight turns is diagnosed.
Conversation Summary
The owner of a 2006 Kia Rio hears a click-click from the driver-side tire area on hard turns and feels it in the steering wheel. The dealer could not reproduce the noise and said the parts checked out. The expert suspects a defective CV joint and advises returning under warranty until the cause is found.
