2002 Kia Rio Steering Wheel Shake
KIA
BRENDA BRISTER
I have a 2002 Kia Rio and just had the tire rotated and balanced because I noticed a slight shaking/shimmy to the steering wheel. The work mentioned didn't help with the problem has about 46,000 mile what wrong with it?
May 31, 2006 at 2:51 PM
CODY-ODY
  • 57 POSTS
Check your tires for any sing of a broken belt,warpage or choppyness.
you might also have mechanical problems such as warped rotors or your wheel bearings might be going.
have you car cheched by someone who knows the vehicle an d product well if you can't see something yourself instead of wasting alot of time and money elsewhere(go to competent dealer).
Jun 18, 2006 at 1:18 AM
Suggested Repair
Inspect the tires for a broken belt, warpage, or choppy wear. Also check for warped brake rotors and worn wheel bearings, preferably at a competent Kia dealer if the cause is not obvious.
Conversation Summary
The owner of a 2002 Kia Rio with about 46,000 miles reports steering-wheel shaking that tire rotation and balancing did not fix. The expert recommends checking the tires for a broken belt, warpage, or choppy wear, and considering warped rotors or failing wheel bearings, with inspection by a competent dealer if needed.
