2001 Kia Rio Bogs, Won't Accelerate
KIA
ORRB
Have 2001 Kia Rio,replaced head and,now have engine check light,and engine bogs,and won't accelerate,put scanner on it and only code that comes up is an E,checked for vacuum,and air leaks,all O.K.,good compression.Got me stumped.
Jun 18, 2006 at 12:39 PM
CODY-ODY
  • 57 POSTS
check the vacuum on the engine with a vacuum guage and see if it flutchuates more than 5hg(mercury inches) and also if the vacuum is within specs( at idle approx 18-23 steady)
if you have low readings it means you have a restriction in the exhaust. If you have a fluctuation it means one or more of your cylinders have low compression.
The code "e" from your scanner ......there is no such code.Try again or with another scanner...codes for vehicles are numbers!
Good luck and I hope I was some help!
Jun 19, 2006 at 1:11 PM
Suggested Repair
Rescan with another scanner because E is not a valid code and codes are numeric. Measure intake vacuum at idle; it should be about 18-23 inHg and steady. Low vacuum points to an exhaust restriction, and fluctuation of more than 5 inHg points to low compression in one or more cylinders.
Conversation Summary
A 2001 Kia Rio has a check engine light, bogs, and will not accelerate after a head replacement. Vacuum leaks were checked and compression was reported good, but the scanner only shows E. The expert said E is not a real code and advised using another scanner, then checking idle vacuum: low steady vacuum suggests exhaust restriction, while fluctuation over 5 inHg suggests low compression.
