Fuel Filter Location?
HMAC300
  • 48,601 POSTS
Check fuel pressure and scan for codes and check fuses underhood. It also may be the anti theft so try resetting it. If you don'thave amanual look online.
Friday, January 22nd, 2021 AT 1:16 PM (Merged)
BUSTERS08
  • 5 POSTS
Thanks and Ride Safe.
RANDYH122
  • 2002 KIA OPTIMA
Engine Performance problem 4 cyl Two Wheel Drive Automatic 141000 miles
I can't find the fuel filter. It is a canister type with threaded fittings on each end. Can you tell me where it is. I have looked undcer neath the car and on the firewall. Can't locate it.
Thanks!
BLUELIGHTNIN6
  • 16,542 POSTS
Should be under car near fuel tank, easiest way to find is just trace fuel lines. Here is a guide to show you what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
https://www.2carpros.com/forum/automotive_pictures/261618_1_158.jpg
Cheers, Ken
