Just replaced thermostat and car is still overheating?
YANKEE
  • 5 POSTS
Cooling fans come on when it runs hot.
I see no coolant leaks anywhere.
Monday, January 25th, 2021 AT 10:30 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Try the bleeding procedures again and see if it helps.
Prior to replacement of the thermostat, was the engine overheating?
Is the new thermostat of the correct rating?
YANKEE
  • 5 POSTS
Yes it was overheating.
I am going to get a thermastat from the dealers parts department.
The one that I brought was from Advance Auto, which even looks different (180).
KHLOW2008
  • 41,814 POSTS
Try running the engine with thermostat removed and see if problem goes away.
Get a test kit for checking presence of carbon in coolant to verify if the head gasket has a problem.
Do you have coolant losses issues before rreplacement of the thermostat?
YANKEE
  • 5 POSTS
Yes, there was loss of coolant at times, I thought it was due to a faulty water pump.
KHLOW2008
  • 41,814 POSTS
After he work done, when engine is cold, was the radiator coolant level checked and was it ok?
Do you still have coolant losses issues?
Have you performed the bleeding as I suggested?
Is there any difference in the situation?
YANKEE
  • 5 POSTS
There is no loss of coolant, after running it with the engine with the radiator cap off for ten minutes at idle, there is no coolant loss. It only happens when I start to drive it. Then it backs up into the resivoir.
After trying everything, I'm inclined to believe that it is the head gasket, although I don't see any leaks.
KHLOW2008
  • 41,814 POSTS
Head gasket leaks would not be visible, if it is, the engine would not be able to run as the damage is very bad and would result in loss of compression. Check if the engine oil has traces of coolant. A test kit would confirm the presence of carbon in the cooling system indicating a bad head.
With coolant filled correctly and radiator cap closed, try revving the engine and checking if coolant is bubbling up at the reservoir.
JJ58551
  • 33 POSTS
It is mostly head gasket. It is causing pressure in your cooling system, which is causing the push out of antifreeze. My bronco is in the shop getting a new engine, it had the same problem. It was easier to put in a engine.
