2000 Jeep Wrangler Broken Bolt
JWISHIN
I have a 2000 Jeep Wrangler, with 85000 mi on a 4cyl engine. I was installing a set of side steps and when removing oen of the bolts between the frame and body it snapped off. What is the best way to get the remaining 2/3 of the bolt out of the body mount?
Mar 14, 2007 at 6:12 AM
PEPPERMRJ
  • 1,158 POSTS
Don't you hate when that happens.
Did the bolt turn at all or is it frozen in place?
Is any of it exposed, enough to get a pair of locking pliers or a stud remover on?
You can also cut a groove into it with a dremmel tool and cutoff wheel and try a screwdriver.
Be sure to soak it overnight with PJblaster what ever you try.
Good luck and let us know. :)
Mar 15, 2007 at 5:17 PM
Suggested Repair
Soak the broken bolt overnight with PB Blaster. If enough is exposed, grip it with locking pliers or a stud remover. Otherwise, cut a slot with a Dremel cutoff wheel and turn it out with a screwdriver.
Conversation Summary
The owner of a 2000 Jeep Wrangler snapped a body-to-frame bolt while installing side steps and asked how to remove the remaining portion. The expert asked whether it was frozen or exposed, then suggested overnight penetrating oil followed by locking pliers, a stud remover, or a screwdriver after cutting a slot.
