2004 Jeep Wrangler Door Panel Won't Come Off
JON BRUCE
I am trying to replace the inside passenger door handle on my 2004 Jeep Wrangler (full doors), and can't get the door panel off, I have removed every screw i could find, what am I missing?
Mar 2, 2006 at 8:54 AM
PEPPERMRJ
  • 1,158 POSTS
A lot of door panels use plug type fasteners in addition to screws. They simply plug into an opening in the frame of the door. Carefully take a small screwdriver and slide it around untill you feel where it is attached. Double check for srews and such and then gently pry the panel out.
Good luck and let us know how it goes. :)
Mar 3, 2006 at 8:41 AM
Suggested Repair
Besides the screws, look for plug-type fasteners that clip into the door frame. Slide a small screwdriver around the panel edge to locate them, confirm every screw is out, then gently pry the panel free.
Conversation Summary
The owner of a 2004 Jeep Wrangler with full doors could not remove the passenger door panel to replace the inside door handle after taking out every visible screw. The expert explained that plug-type fasteners also hold many door panels and advised locating those clips, double-checking the screws, and gently prying the panel off.
