2006 Jeep Wrangler Steering Vibration
ATHAME193
I have a 2006 Jeep Wrangler X and I have been experiencing steering wheel vibration for many months, the dealership has not been able to fix it and they have told me that vibration is normal for jeeps(this is not true b/c my mother bought a new jeep at the same time that i did and she doesn't have a problem). However, I recently had my tires rotated and balanced and this seems to have made the problem worse. When driving on the highway I can take my hands off of the steering wheel and see it shaking around quite a bit. And while the Jeep goes in the general direction that I point it, it feels like it's hard to steer and I have to constantly correct it. What should I have checked? It's gotten to the point that it is difficult to drive the car on the highway and keep it going in a straight line! I also often hear a slight clicking noise when accelerating, if that has anything to do with it.
Feb 9, 2007 at 12:25 AM
BRUCE HUNT
  • 3,754 POSTS
Just the change in the feel by rotation leads me to believe that you have a tire (or more than one) with a bad belt. Say nothing of the alignment.
Feb 9, 2007 at 2:42 AM
ATHAME193
well i had an alignment done and there was no noticeable difference whatsoever. Do you really think that it could be the tires even though they are stock and the problem started when the car was only a couple of months old? How can I tell if that is the problem?
Feb 9, 2007 at 1:25 PM
BOBINYELM
Swap the tires between your mom's new Jeep and yours and see if the problem stays with the vehicle, or moves w/ the tires. That should tell you for sure if the tires/wheels are at fault.
Swap by pairs (Front first, then drive. Rears next, then drive).
Bob
[quote:232c33f33e="athame193"]well i had an alignment done and there was no noticeable difference whatsoever. Do you really think that it could be the tires even though they are stock and the problem started when the car was only a couple of months old? How can I tell if that is the problem?[/quote:232c33f33e]
Feb 10, 2007 at 2:42 PM
ATHAME193
my mom actually has different rims than i do so i don't think that i can do that....can my mechanic let me know for sure if this is the problem? I would just really hate to waste all of that money buying tires if I don't need them!
Feb 10, 2007 at 3:34 PM
Suggested Repair
Have the tires inspected for a separated or broken belt, since rotation made the shake worse and alignment did not help. A shop can road-force balance the tires or compare them by swapping pairs if the wheels fit, before replacing them.
Conversation Summary
The owner of a 2006 Jeep Wrangler X reports long-standing steering-wheel vibration that worsened after a tire rotation and balance, plus wandering that requires constant correction and a slight click when accelerating. The dealer called the vibration normal. An alignment produced no change. Experts suspect one or more tires with a bad belt and suggest confirming that by swapping tires in pairs or having a mechanic inspect the tires before buying new ones.
