Broken Bolt
JEEP WRANGLER
JWISHIN
I have a 2000 Jeep Wrangler, with 85000 mi on a 4cyl engine. I was installing a set of side steps and when removing oen of the bolts between the frame and body it snapped off. What is the best way to get the remaining 2/3 of the bolt out of the body mount?
Mar 14, 2007 at 6:12 AM
PEPPERMRJ
  • 1,158 POSTS
Don't you hate when that happens.
Did the bolt turn at all or is it frozen in place?
Is any of it exposed, enough to get a pair of locking pliers or a stud remover on?
You can also cut a groove into it with a dremmel tool and cutoff wheel and try a screwdriver.
Be sure to soak it overnight with PJblaster what ever you try.
Good luck and let us know. :)
Mar 15, 2007 at 5:17 PM
