1997 Jeep Wrangler Squeal and Knock
Suggested Repair
Clean debris and rubber from the pulley grooves with a small wire brush, and confirm the tensioner moves through its full range. Remove the belt and listen to isolate accessory noise. In this case, an idler pulley was missing bearings and replacing it stopped the noise.
Conversation Summary
A 1997 Jeep Wrangler developed a squeal between 2,000 and 3,000 rpm after the water pump and serpentine belt were replaced. A second belt did not stop it. The expert advised cleaning the pulley grooves and checking tensioner travel. After cleaning, the squeal briefly stopped, then a snap and idle clanging appeared with the belt slightly off center. Removing the belt was suggested to rule out accessories. The shop found an idler pulley missing bearings and replaced it at no charge, resolving the problem.
