2003 Jeep Liberty MAF Sensor Location
JEEP03
  • 21 POSTS
Where is the MAF sensor located? I checked from the filter box along the duct work right up to the throttle body, I can't see the sensor. I asked for the location of the maf sensor, 2003 Jeep Liberty 3.7 liter. I checked for the sensor and I still can't find it. Could you please send me a diagram of it's location
Apr 12, 2007 at 5:36 AM
MERLIN2021
  • 17,250 POSTS
This car does not have a MAF sensor it uses a MAP sensor which is located in the intake manifold. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Apr 16, 2007 at 9:11 PM
Suggested Repair
The 2003 Jeep Liberty 3.7 does not have a MAF sensor. Locate the MAP sensor on the intake manifold instead.
Conversation Summary
The owner of a 2003 Jeep Liberty 3.7 could not find a MAF sensor between the air filter and throttle body and requested a location diagram. The expert explained that this vehicle does not use a MAF sensor and instead uses a MAP sensor located on the intake manifold.
