2003 Jeep Liberty Serpentine Belt Noise
TOBIAS1202
I have a 2003 Jeep Liberty 2wd V-6, & a few days ago, I noticed a grinding noise coming from my serpentine belt area.
At first I thought is was from my power steering pump, because the noise got louder as I turned the steering wheel. I then noticed that the noise was coming from the passenger side of the engine compartment, the power steering pump is on the driver side.
I checked the belt and it is a little worn on the front side of the belt, facing the radiator. I switched off the A/C and noticed that the noise is louder than when the A/C is on.
What could this be, the water pump, A/C compressor, ???
Any advise would be appreciated.
Aug 25, 2006 at 2:19 PM
DEMEARSJR
  • 110 POSTS
Have to know where it's coming from. Get a piece of hose about 2 feet in length, put one end to your ear, and put the other end near where you hear the noise. Have someone turn the wheel, start the a/c, etc. till you can pinpoint where the noise is coming from.
Sep 2, 2006 at 7:14 PM
Suggested Repair
Use a roughly 2-foot hose as a listening tool to pinpoint the grinding noise while someone turns the steering wheel and cycles the A/C, then repair the specific component once located.
Conversation Summary
The owner of a 2003 Jeep Liberty reported grinding from the serpentine belt area that seemed louder when turning and with the A/C off, plus some belt wear. The expert advised isolating the exact source with a hose before assuming the water pump, A/C compressor, or power steering pump.
