2002 Jeep Liberty No Compression
CHADA
My mother has a 2002 Jeep Liberty with a V-6 3.7 motor and there is no compression on the front cyl. and only 10 lb compression on the 2nd cylinder on ther passenger side of the motor.
She owes 2 yrs on the vehicle and does not have alot of momey for repairs, and I'm not very familiar with these new engines.
Any information would be very helpful and appreciated. It is a shame that a vehicle cannot make it past 98,000 miles before something major tears up in the engine.
Thank you for any help
Nov 26, 2007 at 8:40 AM
  • 31,937 POSTS
Hi there,
With 2 cylinders side by side low on compression, one would expect that the head gasket between the cylinders has burnt through. To prove this an air pressure test can be done, With one of the suspect cylinders at T.D.C. an air fitting is screwed into the spark plug hole. low pressure air is fed in. and you will hear it leaking out the other cylinder, you may get a little leak by from the valves, but a fire ring breach like this is quite obvious to a technician. If auto, be careful that the air pressure doesnt kick the engine around, if Manual do it in gear and with the hand brake on.
Good luck
Mark (mhpautos)
Nov 26, 2007 at 1:01 PM
Suggested Repair
Perform a cylinder air-pressure test with a suspect cylinder at TDC and listen for air leaking into the adjacent low-compression cylinder. If that leak is confirmed, the head gasket between those cylinders has likely burned through and should be addressed after diagnosis.
Conversation Summary
The owner reports a 2002 Jeep Liberty 3.7 V6 with no compression on the front cylinder and only 10 psi on the next passenger-side cylinder. The expert says adjacent low-compression cylinders often indicate a burned head gasket between them and recommends an air-pressure test at TDC to confirm leakage into the other cylinder, with care that the air does not rotate an automatic-transmission engine.
