2002 Jeep Liberty Rough Shifting
I plan to drain it, check the pan for debris, etc in the near future. If nothing else that will give me some peace of mind in that regard.
The only code that i get is a small EVAP leak. I think it came from someone not tightening down my gas cap all the way. Its popped up several times. But there have been two or three other people that have used it since so I cant rule out that they didnt tighten it down. Now that its only me driving again, I'll have it erased and make sure that its not something else. Does that make you think of anything else besides the cap? (cant remember the exact number of the code. wanna say that its a 0700 code but cant exactly remember)
thanks!
Suggested Repair
Fix the EVAP leak first, since codes P0442 and P0455 can cause drivability issues. Have the system smoke-tested to locate leaks, starting with the gas cap. Also inspect the transmission fluid for a burnt or brown appearance and change the fluid and filter at about 60,000 miles, checking the pan for debris.
Conversation Summary
The owner of a 2002 Jeep Liberty Sport reports rough shifting, a slight jerk between park and drive, and intermittent sluggish response. The fluid was slightly low at about 60,000 miles, and Lucas transmission additive was added. The fluid looks normal, the U-joints appear tight, and the owner plans to drain the transmission and inspect the pan. Stored codes are P0442 and P0455. The expert says an EVAP leak should be repaired first because it can affect drivability and recommends a smoke test, while also saying a fluid and filter service is reasonable.
