Hi Rpapon, welcome to 2carpros and thank you for the donation.
They all say that about the computer there is more money in it-when the fix relates to an ignition problem, no spark-when you are using the starter fluid.
Do below to determine if it is a fuel or spark problem.
Get a helper disconnect a spark plug wire or two and ground it to the engine at least 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem. Check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer.
SPONSORED LINKS
Sunday, January 5th, 2020 AT 7:47 PM
