1991 Jeep Cherokee Belt Routing
BFRANK4
My son power washed the label with proper routing for this vehicle. The Chilton diagram does not match the correct one for this vehicle. How can I get the proper routing for this vehicle. This vehicle has 75,000 miles on it and changed the water pump. Just need to see a correct diagram for this vehicle. It is a Laredo 4.0L highoutput engine. the vin# is 1J4F58S8ML547848
May 22, 2006 at 3:00 PM
VANDRAGON
  • 298 POSTS
just match the inside grooves with the grooves and the flat side with the flat outside pullies. if you can not figure it out, get someone that knows how to do it. the tension for the belt is adjusted with the altenator.
May 23, 2006 at 3:40 AM
Suggested Repair
Route the belt so the grooved inside face contacts grooved pulleys and the flat side contacts flat pulleys. Adjust belt tension with the alternator. If the routing is still unclear, have someone familiar with the job install it.
Conversation Summary
The owner of a 1991 Jeep Cherokee Laredo 4.0L lost the underhood serpentine belt routing label and said the Chilton diagram did not match the vehicle. The expert advised matching the belt's grooved side to grooved pulleys and the flat side to flat pulleys, and adjusting tension with the alternator.
