1995 Jeep Cherokee No Movement in Gear
FOURWHEELBY
I have a 1995 JEEP Cherokee Laredo automatic and the car starts and turns over but when i put the car in drive or reverse, it doesnt move like its not engaging. help i dont know what to do. maybe a transmission problem? thanks.
Oct 1, 2006 at 4:03 PM
BUBBA_KOSKI
  • 129 POSTS
check the linkage and cable, pop the hood if you see the ball off the socket then go right on ahead and put the ball on the socket, if she still dont work then zip tie her down, but she may be loose because if she was off then the car wouldnt start so she may be loose like i said, the ball should be a tad bit to the drivers side from the center all the way back, on a jeep i believe she may be tad bit to the passengers side though, but check it out and let me know
_____________
ASE Certified
Advance Auto
9289
Oct 4, 2006 at 10:32 AM
Suggested Repair
Check the transmission shift linkage and cable. If the ball is off the socket, reconnect it; if the connection is loose, secure it temporarily and confirm proper alignment.
Conversation Summary
The owner of a 1995 Jeep Cherokee Laredo says the engine starts but the vehicle does not move in drive or reverse. The expert recommends inspecting the shift linkage and cable, reconnecting the ball to the socket if it has come off, and securing a loose connection.
