1991 Jeep Cherokee High Idle No Shift
RELLIKNIKCUF
  • 53 POSTS
I have a 1991 Jeep Cherokee, 4.0 automatic. I went off roading where I took on water. Engine didn't stall and I made it out OK. Engine ran rough for about 5 minutes and cleared up. The 20 minutes drive home was OK and so was the 20mile drive a week later. About a day later I started it up and it idled at 1500-2000 RPMs when normal is around 700-800 RPMs. After a couple of minutes it returns to normal RPM. One time it almost died while idleing for about 5 minutes and got a code "MAP Signal Fault."
I drove the jeep for the first time with the high idle and had to hit passing gear to stay ahead of the traffic. When I got into town in 30 mph zone, it didn't want to shift from 1st. Now, all of the time, I have to get the RPMs up to 3000-3200 RPMs and take my foot all the way off the accelerator for it to shift from 1-2 and 2-3 or let it get all the way up to 4000-4500 RPM and it will shift on it's own. Fluid level is OK and not discolored. Disconnected kick-down cable and still the same. I haven't go a clue abot this and don't want to tear anything apart if it is just a sensor or something simple. Any advice would be greatly appreciated. If I can get the help to fix my problem, I would definitely make a donation since it would save me taking it to a shop. I have always fixed my own vehicles.
Jan 23, 2007 at 1:14 PM
CARUNDELL
  • 602 POSTS
[quote:884f05b167="relliknikcuf"]I have a 1991 Jeep Cherokee, 4.0 automatic. I went off roading where I took on water. Engine didn't stall and I made it out OK. Engine ran rough for about 5 minutes and cleared up. The 20 minutes drive home was OK and so was the 20mile drive a week later. About a day later I started it up and it idled at 1500-2000 RPMs when normal is around 700-800 RPMs. After a couple of minutes it returns to normal RPM. One time it almost died while idleing for about 5 minutes and got a code "MAP Signal Fault."
I drove the jeep for the first time with the high idle and had to hit passing gear to stay ahead of the traffic. When I got into town in 30 mph zone, it didn't want to shift from 1st. Now, all of the time, I have to get the RPMs up to 3000-3200 RPMs and take my foot all the way off the accelerator for it to shift from 1-2 and 2-3 or let it get all the way up to 4000-4500 RPM and it will shift on it's own. Fluid level is OK and not discolored. Disconnected kick-down cable and still the same. I haven't go a clue abot this and don't want to tear anything apart if it is just a sensor or something simple. Any advice would be greatly appreciated. If I can get the help to fix my problem, I would definitely make a donation since it would save me taking it to a shop. I have always fixed my own vehicles.[/quote:884f05b167]
Hey Rell,
Wow! Ummmm .....sounds like a vacuum leak is a good place to start on this one. Inspect all of your vacuum lines/hoses and replace any that may be cracked or broken. Pay close attention to the one going to the MAP sensor too! Let me know!!
Chris
Jan 23, 2007 at 7:53 PM
RELLIKNIKCUF
  • 53 POSTS
[quote:3fa5f40b9e="carundell"][quote:3fa5f40b9e="relliknikcuf"]I have a 1991 Jeep Cherokee, 4.0 automatic. I went off roading where I took on water. Engine didn't stall and I made it out OK. Engine ran rough for about 5 minutes and cleared up. The 20 minutes drive home was OK and so was the 20mile drive a week later. About a day later I started it up and it idled at 1500-2000 RPMs when normal is around 700-800 RPMs. After a couple of minutes it returns to normal RPM. One time it almost died while idleing for about 5 minutes and got a code "MAP Signal Fault."
I drove the jeep for the first time with the high idle and had to hit passing gear to stay ahead of the traffic. When I got into town in 30 mph zone, it didn't want to shift from 1st. Now, all of the time, I have to get the RPMs up to 3000-3200 RPMs and take my foot all the way off the accelerator for it to shift from 1-2 and 2-3 or let it get all the way up to 4000-4500 RPM and it will shift on it's own. Fluid level is OK and not discolored. Disconnected kick-down cable and still the same. I haven't go a clue abot this and don't want to tear anything apart if it is just a sensor or something simple. Any advice would be greatly appreciated. If I can get the help to fix my problem, I would definitely make a donation since it would save me taking it to a shop. I have always fixed my own vehicles.[/quote:3fa5f40b9e]
Hey Rell,
Chris[/quote:3fa5f40b9e]
Hey Chris,
I can't believe it. It was worse than ever this morning on the way to work, then, going home for lunch and stopped at a red light, I pushed the accelerator and it shifted normally. It's been working well ever since. I will check the vacuum lines anyway, thanks for responding so quickly.
Jan 24, 2007 at 10:41 AM
CARUNDELL
  • 602 POSTS
Your welcome!!
Jan 24, 2007 at 10:47 AM
RELLIKNIKCUF
  • 53 POSTS
Aaahhh!!! It's doing it again. I left for lunch and it didn't want to shift again. When it ws shifting normal, it also idled normal. So the high idle and shifting problem are definitely related. I also got a new trouble code, 41 Fault in the charging system or no field current. Thanks for your help.
Jan 31, 2007 at 4:32 AM
CARUNDELL
  • 602 POSTS
[quote:5c50c96527="relliknikcuf"]Aaahhh!!! It's doing it again. I left for lunch and it didn't want to shift again. When it ws shifting normal, it also idled normal. So the high idle and shifting problem are definitely related. I also got a new trouble code, 41 Fault in the charging system or no field current. Thanks for your help.[/quote:5c50c96527]
Is your "kick down" (passing gear) a cable set up or linkage? It may be binding/sticking causing both conditions. Manually operate the throttle from underhood and see if its keeping the throttle open and binding on the kickdown linkage
Chris
Jan 31, 2007 at 4:41 AM
RELLIKNIKCUF
  • 53 POSTS
It is a cable setup. It goes straight into the transmission with no visible moving parts. I disconnected the kick-down cable the day before it started working again and never hooked it back up. I thought that might be what fixed my problem, but it returned today and the kick-down cable was still disconnected. I'm not sure what else it could be.
Jan 31, 2007 at 9:57 AM
RELLIKNIKCUF
  • 53 POSTS
Turned out to be the TPS, funny, no code evr came up for the TPS.
Jul 1, 2007 at 12:35 PM
Suggested Repair
Inspect all vacuum hoses, especially the line to the MAP sensor, and check for a binding throttle or kickdown cable. The owner later reported the throttle position sensor (TPS) was the cause even though no TPS code set.
Conversation Summary
A 1991 Jeep Cherokee 4.0 automatic ran rough briefly after taking on water, then developed a high idle, a MAP signal fault, and delayed 1-2 and 2-3 shifts. Fluid looked normal and disconnecting the kickdown cable did not fix it. An expert suggested checking vacuum leaks, especially the MAP hose, and whether the throttle or kickdown linkage was binding. A charging-system code 41 also appeared. The owner later reported the problem was a bad TPS, with no TPS code.
