1991 Jeep Cherokee High Idle After Gasket
MIHAI_HUSTIUC2000
I have a 91 jeep cherokee and just replaced the intake and exaust gasket but now i just started it right after and it goes and idles at 3500 to 4000 any answeres why this might happen?
Aug 20, 2006 at 6:44 PM
DEMEARSJR
  • 110 POSTS
You disconected the battery I assume.
Let it do this for a couple of days and it might straighten itself out.
If it doesn't check your throtle cables they might have gotten stretched or misaligned when you reinstalled them.
Sep 2, 2006 at 7:43 PM
Suggested Repair
After the battery was disconnected, allow a couple of days for the computer to relearn idle. If the high idle continues, inspect the throttle cables for stretch or misalignment from reinstallation.
Conversation Summary
The owner of a 1991 Jeep Cherokee reports idle of 3500 to 4000 RPM right after replacing the intake and exhaust gaskets. The expert says the computer may settle after a couple of days following battery disconnect, and if not, the throttle cables should be checked for stretch or misalignment.
