Make sure you plugged the coolant temperature sensor back in. Did you change the thermostat.
People have been known to put them in backwards.
Re-inspect everthing you touched and everything else nearby where you were working.A loose connection at a sensor, vacuumn line, or even a loose ground wire can cause a rough running condition.
Monday, December 17th, 2007 AT 7:11 PM
