When I start it, it will sometimes idle really high then if I give it a second will idle back down to the correct rpm. However, the other day it started to idle high while in drive as well. I had problems with the throttle sticking before but I checked it on the engine and it seemed fine. Could this be a vacuum leak, have yet to check for those, or some other type of problem?
SPONSORED LINKS
Saturday, September 23rd, 2006 AT 11:46 AM
