1998 Jeep Cherokee Engine Cuts Out
HUBBABUBBA
I have a 1998 Jeep Cherokee Sport with 106,000 miles on it. It has been in the shop for 7 weeks and they do not know what is wrong. The check engine light is on. When I drive it, the engine will die while coming to a stop or taking off from a start. They scanned the PCM to diagnose codes PO123 TPS voltage high. They replaced TPS sensor and checked output TPS voltage, they say its good for now but signal wire to PCM from TPS has 5.3 volts coming out of PCM with TPS signal removed. Form some reason PCM is putting voltage out on circuit #A23 when it should only be receiving a voltage line from TPS. Can you please help. Our mechanic is stumped as are we. Are we even on the right track to solve this engine problem????? Thank you
Stacy
Mar 29, 2006 at 11:55 AM
PEPPERMRJ
  • 1,158 POSTS
[quote:50f0c91abe="hubbabubba"]I have a 1998 Jeep Cherokee Sport with 106,000 miles on it. It has been in the shop for 7 weeks and they do not know what is wrong. The check engine light is on. When I drive it, the engine will die while coming to a stop or taking off from a start. They scanned the PCM to diagnose codes PO123 TPS voltage high. They replaced TPS sensor and checked output TPS voltage, they say its good for now but signal wire to PCM from TPS has 5.3 volts coming out of PCM with TPS signal removed. Form some reason PCM is putting voltage out on circuit #A23 when it should only be receiving a voltage line from TPS. Can you please help. Our mechanic is stumped as are we. Are we even on the right track to solve this engine problem????? Thank you
Stacy[/quote:50f0c91abe]
Double check everything. Most PCMs send out a 5 volt reference to the TPS. The return voltage is how the PCM relates. It should not be higher than the input. Double check your checks and all the associated wiring for shorts to power.
After that time for a PCM from the junkyard.
Good luck and let us know. :)
Mar 29, 2006 at 12:04 PM
Suggested Repair
Recheck the TPS circuit and associated wiring for shorts to power. Confirm the PCM 5-volt reference and that the signal return is not higher than the reference. If the wiring checks out and high voltage remains on the signal circuit with the TPS disconnected, replace the PCM.
Conversation Summary
A 1998 Jeep Cherokee Sport with 106,000 miles stalls when stopping or pulling away, with the check engine light on and code P0123 for high TPS voltage. The TPS was replaced, but about 5.3 volts was still measured on the signal circuit with the sensor disconnected. The expert advised rechecking the wiring for shorts to power and, if those checks are good, replacing the PCM.
