1994 Jeep Cherokee Stalls Taking Off
SHARK3149
Hello.I am in need of some help.I have a 94 Cherokee sport 4.0 4w.d. with 218,378 miles.The problem I am having is the truck will stall when taking off from a stop,or making a turn.This does not happen all the time,some times when it is hot and some times when its cold.I can go for months and not have a problem but then it might act up 3 or 4 times.The truck starts right back up after a Minuit or two then will run great.I love my Jeep but this is starting to get on my nerves.Please any help will be greatly appreciated.Thank you.
The check engine light has never come on for this problem.
Oct 3, 2007 at 6:44 PM
  • 75,988 POSTS
Get it scanned for OBD2 code/s with or w/o CEL On.
A good place to look, for a start is the TPS and MAP/MAF or a sensor that senses the engine load.
Oct 3, 2007 at 8:13 PM
SHARK3149
[quote:62e4023866="rasmataz"]Get it scanned for OBD2 code/s with or w/o CEL On.
A good place to look, for a start is the TPS and MAP/MAF or a sensor that senses the engine load.[/quote:62e4023866]
Thank you.I will check these out.The check engine light has not come on when this happens.
Oct 4, 2007 at 2:02 AM
KRAZY
YOU HAVE WHAT IS CALLED A CHOKE CENSOR THAT LETS THE FUEL INJECTION SYSTEM KNOW WHEN TO AND WHEN NOT TO SEND FUEL TO THE SYSTEM COULD BE IT COST ME ABOUT $60 FOR THE PART HAVEN'T HAD A PROBLEM SINCE
Oct 23, 2007 at 7:54 AM
SHARK3149
[quote:347e22f86c="krazy"]YOU HAVE WHAT IS CALLED A CHOKE CENSOR THAT LETS THE FUEL INJECTION SYSTEM KNOW WHEN TO AND WHEN NOT TO SEND FUEL TO THE SYSTEM COULD BE IT COST ME ABOUT $60 FOR THE PART HAVEN'T HAD A PROBLEM SINCE[/quote:347e22f86c]
Thank you for the help.I will check that out.I am just about to trade it in on a new suv.
Nov 18, 2007 at 5:05 PM
SHARK3149
[quote:54c73b153b="shark3149"][quote:54c73b153b="krazy"]YOU HAVE WHAT IS CALLED A CHOKE CENSOR THAT LETS THE FUEL INJECTION SYSTEM KNOW WHEN TO AND WHEN NOT TO SEND FUEL TO THE SYSTEM COULD BE IT COST ME ABOUT $60 FOR THE PART HAVEN'T HAD A PROBLEM SINCE[/quote:54c73b153b]
Thank you for the help.I will check that out.I am just about to trade it in on a new suv.[/quote:54c73b153b]
Thanks to every one who tried to help.I still could not fix the problem so I sold the truck to a neighber and bought a new truck.
May 13, 2008 at 6:23 AM
Suggested Repair
Scan for diagnostic codes even if the check engine light is off, then inspect the throttle position sensor and the MAP/MAF or another engine-load sensor. The stalling was not confirmed as fixed.
Conversation Summary
The owner of a 1994 Jeep Cherokee with a 4.0 engine reported intermittent stalling when pulling away from a stop or turning, in both hot and cold conditions. The engine restarted after a minute or two and then ran normally, with no check engine light. An expert recommended scanning for codes and checking the TPS and MAP/MAF or another load-sensing sensor. Another user suggested a choke sensor, but the owner could not resolve the issue and sold the vehicle.
