1994 Jeep Cherokee Stalling and having to sit a while befor
JULIAOGO
  • 1994 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 116,000 MILES
I have 1994 Jeep Cherokee, 4wd and a few weeks ago I was driving and it just cut off, like it was not getting fuel. When I was able to get it started again, the same thing happened several times in a row (like 6 times. I didnt have the problem for about 2 more months, now all of a sudden, same thing. It cut off while running and wont re-start until after it has set for a long period of time. Could a bad Catalytic Converter cause this to happen? Thanks Julia
Friday, August 21st, 2009 AT 10:35 AM
  • 109,885 POSTS
Julia:
A converter will cause a loss of power and can cause the engine to die, but not how you described it. My first guess is the fuel pump, but I need to know if the check engine light came on before having you check the pump.
Monday, August 24th, 2009 AT 9:41 PM
