1998 Jeep Cherokee Rear Washer and No-Start Fix
DSINKA
This site rocks.. just found it and now it's bookmarked..
Anyway, i have a 1998 Jeep cherokee classic with 190,000 miles on it....My rear wiper blade has a sprayer nozzle on it, but i broke it. I cannot find another one online or anything dont really want to got to the junkyard..there has to be somewhere i can buy one online or something right?. Also, my rear wiper arm that dispenses this washer fluid isnt dispensing it...does the motor that moves the arm also pump the fluid? my arm still works and my front wipers still work and spray fluid so if i buy a new motor will it also start pumping fluid? Last question and i will donate to your cause buddies, my car jeep sometimes when parked on an incline wont start..i found that if i shove the gear shifter up past the park it will start...shifter linkage??? if this sounds right please tell me, also where is it? ..thanks guys. i will be eagerly awaiting yur reply.
Derek
Dec 27, 2006 at 12:27 PM
2CARPRO JACK
  • 11,533 POSTS
Welcome. The rear wiper piece might be available from Jeep, otherwise its off to the junk yard.The washer lines get plugged up from the washer fluid drying, be sure all lines are clear before replacing the pump.If you have power at the pump and its not working then you need another.The starting issue could be the shifter adjustment or the Neutral Safety Switch adjustment. Good Luck
Dec 28, 2006 at 1:25 AM
Suggested Repair
Check the rear washer lines for plugs from dried fluid before replacing the pump. If the pump has power but does not work, replace it. The rear wiper spray piece may be available from Jeep or a salvage yard. For the incline no-start that starts when the shifter is pushed past Park, check shifter adjustment and the neutral safety switch.
Conversation Summary
The owner of a 1998 Jeep Cherokee has a broken rear wiper spray nozzle, no rear washer spray though the arm and front washers work, and an intermittent no-start on inclines that starts if the shifter is pushed past Park. The expert says the nozzle may come from Jeep or a junkyard, to clear plugged washer lines before replacing the pump and replace the pump only if it has power and does not work, and to check shifter or neutral safety switch adjustment.
