1993 Jeep Cherokee Won't Start
C_EBERLE
I have a 1993 Jeep Cherokee and it won't start. It will turn over and the fuel pump is working. I can hear it everyitme I turn the ignition key on. I had a fellow out to check and he says it may be the the coil. He says there is no power going from the coil but all fuses, relays have power. Could it be the ignition switch?
May 31, 2007 at 5:39 PM
  • 75,988 POSTS
[quote:ae72e01e7e="c_eberle"]I have a 1993 Jeep Cherokee and it won't start. It will turn over and the fuel pump is working. I can hear it everyitme I turn the ignition key on. I had a fellow out to check and he says it may be the the coil. He says there is no power going from the coil but all fuses, relays have power. Could it be the ignition switch?[/quote:ae72e01e7e]
Could be the coil,crankshaft position sensor/distributor pick-up.
Jun 1, 2007 at 9:32 AM
ISOM
[quote:ddd5c84bd6="c_eberle"]I have a 1993 Jeep Cherokee and it won't start. It will turn over and the fuel pump is working. I can hear it everyitme I turn the ignition key on. I had a fellow out to check and he says it may be the the coil. He says there is no power going from the coil but all fuses, relays have power. Could it be the ignition switch?[/quote:ddd5c84bd6]
It's the crankshaft sensor locate on the driver side rite on top of the bell house. two screws and a plug. an $50 to $75 for one
Jun 2, 2007 at 8:33 AM
Suggested Repair
Check the ignition coil, crankshaft position sensor, and distributor pickup. The crankshaft sensor is on the driver side on top of the bellhousing, secured by two screws with a plug, and typically costs about $50 to $75.
Conversation Summary
The owner of a 1993 Jeep Cherokee reports a no-start that cranks and has an audible fuel pump. A helper found no power from the coil even though the fuses and relays had power, and asked whether the ignition switch could be at fault. Replies suggest the coil, crankshaft position sensor, or distributor pickup, and one reply specifically identifies the crankshaft sensor on the driver-side bellhousing.
