1999 Jeep Cherokee Overheated Won't Start
CHRYSLER
ROB1208
My 99 jeep cherkee overheated now it won't start. I've replaced the thermostate and checked to see if there was any coolant in the oil and there was none. It will turn over but not fire.
Jan 9, 2007 at 2:49 AM
CARUNDELL
  • 602 POSTS
[quote:1bc6da54a9="rob1208"]My 99 jeep cherkee overheated now it won't start. I've replaced the thermostate and checked to see if there was any coolant in the oil and there was none. It will turn over but not fire.[/quote:1bc6da54a9]
Hey rob,
Thats not a good sign. Do your basic checks for spark and fuel. If all is ok then IMMEDIATLY do some cylinder compression testing as you may have a head gasket failure. Let us know!
Chris
Jan 9, 2007 at 4:56 AM
Suggested Repair
Check for spark and fuel. If both are present, perform a cylinder compression test immediately to check for possible head gasket failure after the overheating.
Conversation Summary
A 1999 Jeep Cherokee overheated and now cranks but will not start. The owner replaced the thermostat and found no coolant in the oil. The expert advised checking spark and fuel, then doing a compression test right away because a head gasket may have failed.
