1988 Jeep Cherokee Overheated Won't Start
RAINDANCER
I have a 1988 Jeep Cherokee Sport with a V-6 with ~111,000 miles on it. It ran out of coolant and overheated so that steam was billowing out of the plastic container. We added about 1.5 gallons of water and antifreeze and it cooled off. But now the engine won't turn over. The belts move when I turn the key and it sounds right but engine doesn't fire. What should I check out?
Mar 1, 2007 at 8:01 AM
CHEVY22
  • 1,375 POSTS
hi
i would check the compression on all cylinders if you need the spec et me know , i would do the test and record what you have and get back to us
yhanks
jim
Mar 1, 2007 at 9:36 AM
RAINDANCER
What is the spec?
Mar 1, 2007 at 11:39 AM
CHEVY22
  • 1,375 POSTS
its 120 -150 psi , lwt me know what you get
thanks
jim
if you are happy with the info please leave feedback we all here do this for free feedback is a way of saying thank you for the help
Mar 1, 2007 at 12:11 PM
Suggested Repair
Perform a compression test on all cylinders and record the readings. Compare them with the stated specification of 120-150 psi, then report the results.
Conversation Summary
The owner of a 1988 Jeep Cherokee with a V6 said it ran out of coolant and overheated, with steam coming from the plastic reservoir. After adding about 1.5 gallons of water and antifreeze, it cooled, but the engine cranks without firing. The expert recommended checking compression on all cylinders and gave a specification of 120-150 psi.
