1996 Jeep Grand Cherokee AC Leak
JOYLOU
I have a 1996 Jeep Grand Cherokee Laredo with 150000 miles and a 5.2 engine. When we run the air conditioning it leaks inside the jeep on the passenger side floor.
Aug 25, 2007 at 4:10 AM
GRICHARDS
  • 57 POSTS
It's likely that the AC "evaporator condensate Drain Tube" is clogged, disconnected, or cracked. Underneath the passenger side dash is an assembly called the "Heater/AC Housing" (Black Plastic). Connected to this assembly is a drain tube that goes from inside the passenger compartment, through the front firewall, then down so the condensation/water can drain onto the ground. EXACTLY where the tube is located on a J.G. Cherokee I'm not quite sure, it may route from the firewall then into the right front wheel well area (behind the splash guard). Most "Water in passenger floorboard" when AC running problems are this... Anyone out there with a JGC that knows the exact location? Hope this helps!
Aug 25, 2007 at 5:11 AM
Suggested Repair
Inspect the AC evaporator condensate drain tube under the passenger-side heater/AC housing. Clear a clog, reconnect it if loose, or replace it if cracked. It may route through the firewall toward the right front wheel well behind the splash guard.
Conversation Summary
The owner of a 1996 Jeep Grand Cherokee with a 5.2 engine reports water leaking onto the passenger floor when the air conditioning runs. The expert says the evaporator condensate drain tube is likely clogged, disconnected, or cracked, and describes it as running from the heater/AC housing through the firewall so condensate can drain outside. The exact routing on this model was not confirmed.
