ac leaking water in passenger floor board and cutting out
NATTER1
ac leaking water in floor board on passanger side and the vents that blow cold air to driver cuts off after 30mph and blows cold air to the floor and the defrost
vents
Aug 4, 2007 at 1:25 AM
DPWD23
  • 136 POSTS
For the water issue, clear the condensation tube/make sure it's connected.
Check the vacuum lines for the other issue. it uses vacuum motors to move the dampers that controll where the air goes.
Aug 4, 2007 at 5:06 PM
