1993 Jeep Grand Cherokee AC Leak
BURTON WEISMAN
1993 Jeep Grand Cherokee, Ltd.
6-cyl
4WD All the time
188,000 miles
Transmission Cooler installed for Travel Trailer Towing
Since 2005 we have been refilling the R-134A refrigerant approximately every 2-weeks because it leaks out.
No one can tell us where the leak is. Repair estimates vary from $700 - $1,500. Some think the problem is that the evaporator needs replacement, but the source of the leak has never been diagnosed.
The AC works reliably and blows ice cold until the refrigerant leaks out.
I've read much about AC system products that stop leaks. Is this viable and affordable?
How should we approach this problem? We're driving 3,000 miles back down to Belize this October 07 with our 3 dogs and cannot consider this run without reliable AC.
Thank you very much for any advice you can provide.
We've gladly provided a donation for your expertise.
Kind regards,
Burton Weisman
Ojai, CA
310-488-3319
Jul 20, 2007 at 8:05 AM
2CARPRO JACK
  • 11,533 POSTS
I dont recommend the use of any kind of stop leak in a/c systems.You need to go to a shop that specializes in a/c, I cant see why no one can find it, especially if it leaks out that fast
Jul 20, 2007 at 10:37 AM
DPWD23
  • 136 POSTS
if your mechanic won't do it for you, buy a refirdgerant with a UV dye added to it. Drive it for a couple days and using a UV pen and glasses, look over the ENTIRE system until you find the dye. If it is leaking this fast, you will definately find it. If you are not comfortable doing this yourself, make sure that the mechanic is using a UV dye to look for leaks, not just looking for oil.
You can try once the system is fully discharged replacing the refill valves. Auto parts stores sell a kit with 2 valves and a tool to pull them out, but the system must have NO pressure, and should be pulled to full vacuum before refilling.
If nobody can find your leak, you will likely need to find it yourself. I too do not recomend adding any stop leak stuff to nearly any system. Usually do more harm than good.
If your system has been converted from r12 to 134a, try refilling and taking your adaptor off the low side, and don't even bother with one on the high side. I have seen converted systems leak from the fill port because of faulty adaptors.
Jul 20, 2007 at 5:09 PM
Suggested Repair
Do not use AC stop-leak. Have an AC specialist locate the rapid leak with UV dye rather than only looking for oil. Check converted R-12 to R-134a service-port adapters, and consider replacing the service valves only after the system is fully discharged and pulled to vacuum before recharging.
Conversation Summary
The owner of a 1993 Jeep Grand Cherokee says the AC loses R-134a about every two weeks and shops have not found the leak, with estimates varying and evaporator replacement suggested without a confirmed diagnosis. Experts advise against stop-leak products, recommend an AC specialist and a UV-dye inspection of the entire system, and note possible leaks at converted fill-port adapters or service valves.
