1997 Jeep Cherokee Hard Start
TODD1124
1997 Jeep Cherokee 6cyl
Somtimes it starts fine and other times it will crank and crank. At times giving it a little gas when it is cranking will help it start. It does not seem to matter if the engine is hot or cold. Any ideas?
Jul 19, 2007 at 4:08 AM
DPWD23
  • 136 POSTS
First start by checking the fuel pressure at the fuel rail. If it falls within specs, next try to borrow a set of noid lights, and hook them up in place of the fuel injectors. If I remember correctly this models injectors fire 3 at a time. Three should light, then the other three should light... or they should all light on their own, but either way, all 6 should light. Have someone crank the engine while you watch the noid lights.
If they all light hook the fuel injectors back up. At this point you will have eliminated the fuel pump and electrical connections at the fuel injectors. It is possible that you have a failing fuel pump relay, as it primes the fuel system in preperation to start. They are fairly inexpensive, especially if you use an aftermarket part.
If everything here tests out just fine, please reply and we can do some more diagnostic testing.
Jul 19, 2007 at 6:52 AM
Suggested Repair
Check fuel pressure at the fuel rail. If it is within spec, use noid lights on all six injectors while cranking to confirm they fire. If those tests pass, suspect a failing fuel pump relay and replace it with an inexpensive aftermarket unit if needed, then continue diagnostics.
Conversation Summary
A 1997 Jeep Cherokee 6-cylinder sometimes starts normally and other times cranks without starting, whether hot or cold; a little throttle while cranking can help. The expert recommends checking fuel-rail pressure, then verifying injector pulse with noid lights. If those checks pass, a failing fuel pump relay is a likely next suspect, with further testing if everything checks out.
