1994 Jeep Grand Cherokee Intermittent AC
CMV1
Jeep Grand Cherokee '94, 140,000 mi., 4.0 liter, manual transmission.
Ongoing a/c problem can't be located by dealer service techs. Air conditioning works great only occasionally. It will stop working for days on end, and then suddenly begin working again for whatever period of time it pleases, then stop.
Dealer techs are stumped. The only clue I have is that the cessation (or resumption) of the a/c happens after car has been stopped and the ignition has been turned off, and then on again for the next trip.
When the a/c is working, the air is very cool and blows just as it should do all the time.
Do you have any suggestions?
Jun 19, 2007 at 9:57 AM
2CARPRO JACK
  • 11,533 POSTS
Test the low side cycling switch,should have power on both terminals. If the switch is borderline and you try to pull too much amperage through it it will lose contact
Jun 20, 2007 at 1:24 AM
Suggested Repair
Test the low-side cycling switch and confirm it has power on both terminals. A borderline switch can lose contact if too much current is drawn through it, causing intermittent A/C operation.
Conversation Summary
A 1994 Jeep Grand Cherokee with 140,000 miles has intermittent air conditioning that works well for a while, then stops for days and resumes after the ignition is turned off and back on. Dealer technicians could not find the cause. The expert advised testing the low-side cycling switch for power on both terminals, noting a borderline switch can lose contact under higher current draw.
