1996 Jeep Grand Cherokee AC Fumes
JESSICA FRY
I have a 96 Jeep Grand Cherokee, auto, 4 wheel drive, 230,000miles. The air conditioner is putting out strange fumes that smell like propane. Also, there are water spots on my floorbaords. A mechanic told me the drain is clogged and the water is not draining properly. Is this something that can cause health problems. Also, catalytic converter was replaced. I have read this could produce an odor also. Any suggestions?
Jul 31, 2007 at 4:43 AM
MERLIN2021
  • 17,250 POSTS
You mechanic is right about the drain. Get a can of computer air and use the straw and insert it into the hole at the bottom of the passenger firewall, under the hood. A bad converter can smell like Sulfer.
Aug 1, 2007 at 8:03 AM
Suggested Repair
Clear the clogged A/C evaporator drain by inserting the straw from a can of compressed air into the drain hole at the bottom of the passenger firewall under the hood. A bad catalytic converter can also produce a sulfur-like odor.
Conversation Summary
The owner of a 1996 Jeep Grand Cherokee reports propane-like fumes from the air conditioner and water spots on the floorboards. A mechanic said the drain is clogged, and the owner also asks about health effects and whether a replaced catalytic converter could cause odor. The expert agrees the drain is clogged and recommends clearing it with canned air at the passenger firewall drain hole, noting that a bad converter can smell like sulfur.
