1997 Jeep Cherokee Belt Squeak
(K2)
Jeep
Cherokee
1997
~110K miles
V6 4WD
I recently replaced the water pump, thermometer, gaskets and belt. After flushing the coolant, I noticed a leak and had to reseal the thermometer gasket. Antifreeze got all over the engine, including the belt. I think I've tightened the belt enough, but it still squeaks for a few seconds when the car is started cold. When the AC is turned on, it squeaks even more, but not after the car is warmed up. The car was not squeaking at all before I had to replace the water pump. What could this be? Just replace the belt or tighten it more? Or is this a more serious problem?
Oct 23, 2007 at 5:00 AM
2CARPRO JACK
  • 11,533 POSTS
Try cleaning the pulleys real good with carb spray.Might have contaminated the belt, but try tightening it a little bit to see if the noise goes away after you clean the pulleys
Oct 23, 2007 at 5:08 AM
Suggested Repair
Clean the pulleys thoroughly with carburetor cleaner, then slightly tighten the belt and recheck the cold-start squeak. The belt may be contaminated by antifreeze.
Conversation Summary
The owner of a 1997 Jeep Cherokee replaced the water pump, thermostat, gaskets, and belt. After a coolant leak and reseal, antifreeze covered the engine and belt. The belt now squeaks briefly on cold starts and more with the AC on, but not once warm. It did not squeak before the water pump job. The expert advised cleaning the pulleys well with carburetor spray because the belt may be contaminated, then tightening the belt slightly to see if the noise stops.
