98 Jeep Cherokee 4L 6cyl 4x4 177k Manual
TDM757
The following problems are a mystery to me:
1) There is a load and constant rattling noise when the clutch is not pushed in, and it is louder in lower gears.
2) When I reverse, there is sometimes a loud and constant clanking noise.
3) When I put it in 4wd, and turn alrmost hard left or right, the wheel pushes back hard against the direction i'm turning, and won't let me go to wheel lock.
4) I refill the AC with the R134a cans every May, as every september, the AC stops blowing cool air. It is fine almost everytime else. Any ideas, why I have solid and constrant pressure for a few months, then nothing?
Any help any of you can provide would be appreciated. TM
Apr 19, 2007 at 5:03 AM
MERLIN2021
  • 17,250 POSTS
How do I love thee, let me count the ways!
1.) Throw out bearing...time to do a clutch job!
2.) See 1 above!
3.) Grease is missing on stops.
4.) Leaks! Most R-134a comes with a dye load this type this May and get a leak test!
Apr 19, 2007 at 9:59 AM
