Serpetine Belt Routing for 1991 Jeep Cherokee Laredo
1991 JEEP CHEROKEE
BFRANK4
My son power washed the label with proper routing for this vehicle. The Chilton diagram does not match the correct one for this vehicle. How can I get the proper routing for this vehicle. This vehicle has 75,000 miles on it and changed the water pump. Just need to see a correct diagram for this vehicle. It is a Laredo 4.0L highoutput engine. the vin# is 1J4F58S8ML547848
May 22, 2006 at 3:00 PM
VANDRAGON
  • 298 POSTS
just match the inside grooves with the grooves and the flat side with the flat outside pullies. if you can not figure it out, get someone that knows how to do it. the tension for the belt is adjusted with the altenator.
May 23, 2006 at 3:40 AM
