Based on your description, either the battery is too weak or the starter is going bad. First, make sure the battery terminals are clean and tight. Next, place the battery on charge to fully charge it. Then see if it starts. If it still does the same thing, remove the battery and have it load tested at the local parts store. If it is good, remove the starter and have it bench tested to make sure it isn't drawing too many amps.
Let me know what you find.
SPONSORED LINKS
Sunday, January 3rd, 2010 AT 5:08 PM
